TO35 compresion test results
Max Pfrimmer
01-08-2006 15:25:09
I just bought a TO35 that backfires (pops)every few secounds. The compresion test dry results are 125, 125, 145, 100. I tested the last one (#4) wet and it went to 125. I guess it must be rings for that one. I was hopeing it would be valves for an easyier fix. I did find a broken rotor, piece off it's side. Any thoughts Thanks
Jerry/MT
01-08-2006 19:17:20
 Re: TO35 compresion test results in reply to Max Pfrimmer, 01-08-2006 15:25:09
First of all, did you do the compression test with the engine at operating temperature and with the throttle plate wide open? If you did then I suppose your numbers are accurate. I wouldn't worry about immediately doing an overhaul cuz even the low cylinder is not that bad. To me a "backfire" is a sharp, loud, noise almost like a 22 rifle being fired. A pop is like a cylinder misfiring so I'm not sure I understand what you mean by a "...backfire(pop)...". I would check the ignition system (fat, bluish spark) and timing, paying particular attention to the mechanical condition of the distributor. A lot of these distributors have worn shaft/bushing that causes misfire. If your ignition system and your distributor are fine, make sure the carb is properly adjuted because an improper mixture can cause misfire. I also agree that the valves may be a problem since there is a "pop" in the exhaust. Could be a burned valve or a carbon deposit.
ErnieDD
01-08-2006 16:50:33
Bet you have old gas, the intake valves gummed up and sticking slightly. #4 runs hot, always seems to be a tad lower in compression.
Fresh gas with a couple of shots of 30 wt oil and work the snot off it. Then do your compression test.
Next time you comprssion test, loosen plug 2 turns, then install wires and run for just a second to blow the carbon flecks out. May hang up a valve and give you false low readings.
gerard
01-08-2006 16:04:20
Having checked ignition, I'd still check to see if there's a broken valve spring. Worn / stuck rings may produce many symptoms, but 'popping' isn't one of them.
Mas P
01-08-2006 20:10:24
 Re: TO35 compresion test results in reply to gerard, 01-08-2006 16:04:20
I did forget to open the throttle all the way. How much difference will that make?
