Connecting rod Order
Doug NC
01-08-2006 07:42:16
I rebuiling my TO-30, When I took out the Connecting rods the Stamped numbers on the rods came out in firing order 1-3-4-2. Is that how they should be? Or shoud the rod numbers match the cylender number 1-2-3-4 ??? I know that the motor had been rebuilt before.
Doug NC
01-08-2006 13:22:06
 Re: Connecting rod Order in reply to Doug NC, 01-08-2006 07:42:16
Guys thanks for the info, This is a total rebuild, reman block, new pistons and sleeves. I might need more help later!!
1466max'd
01-09-2006 07:52:34
 Re: Connecting rod Order in reply to Doug NC, 01-08-2006 13:22:06
were did you get the "remaned" block at? or did you send yours some place?
Doug NC
01-10-2006 09:49:45
 Re: Connecting rod Order in reply to 1466max'd, 01-09-2006 07:52:34
I got the block through Worthing AG in Goldsboro NC. $650 + shipping, It is a good looking block. My old block was in bad shape, it had been pinned before and was cracked through the center main, and between #2 and #3 cylinder
gerard
01-08-2006 12:19:18
John is right, but if its been running like that for some time & you intend putting it back together without fitting new pistons or crank bearings, etc. I"d put it back as it came apart, now the parts have bedded together.
John (UK)
01-08-2006 08:17:22
They should match the cylinder numbers.
