Ferguson 35 Deluxe oil levels
grimme
01-07-2006 09:59:02
where do you check the transmission oil level and where do you fill differential housing? thanks
John (UK)
01-08-2006 06:04:08
 Re: Ferguson 35 Deluxe oil levels in reply to grimme, 01-07-2006 09:59:02
The filler for the hydraulics and transmission is on the left side alongside the gear levers on the gearbox cover. It holds 32 US quarts. The oil can be 90w GL1 or you can now use Multi-grade 15W/30, this will be more fluid when it cold and thicker when its hot and you should be able to find it easier to buy. Clean the magnets on the drain plugs and check for any lumps of metal, if there is there could be something breaking up inside.Dipstick is on right side below hydraulic levers. If you need the correct information on how to operate the hydraulic system correctly, email me at:- fergusontractors (at) tiscali.co.uk and ask me for it.
Jerry/MT
01-07-2006 17:27:46
 Re: OOPS!!!!!!...Ferguson 35 Deluxe oil levels in reply to grimme, 01-07-2006 09:59:02
Oops! I gave the fill instructions for the TO-30. I'm not sure about the trans/hydraulic oil quantity for the TO-35. Check your owners manual. Sorry
Jerry/MT
01-07-2006 17:19:24
Before you refil the oil, especially if it's water contaminated, you might want to consider flushing the sumps out with diesel or kerosene. Jeff(OH) has a method to do this outlined in the archives that you might find useful.
Be careful to not overfill. If you remove the bottomost bolt in the right hand side acess cover(the one with the dipstick)and fill til the fluid runs out of the the bolt hole you be just right. Make sure that you use a GL1 type oil or equivalent. NO GL4 or GL5.
Jeff-oh
01-09-2006 05:27:32
 Re: Ferguson 35 Deluxe oil levels- cleaning proced in reply to Jerry/MT, 01-07-2006 17:19:24
It has been a while since this was posted. It does work well. I was just at TSC on Sat and their GL-1 oil is not $46.00/5 gal. WOW.
This is the procedure I used to clean my transmission oil housing. You will need to wash out the old fluid. Any remaining fluid will contaminate the new fluid. If you have time in the evenings start to drain the tractor now. She will drip for hours/days.
You should also be prepared to deal with the gallons of fluids you the will gush out of the tractor. Have containers ready to pour the old oil in to take to your auto parts store for recycling.
Do your lift arms drop/leak down quickly? If so prior to draining the fluid pull the right and left side inspection plates. Lift an implement and look to see where the fluid is leaking out of the system as the lift lowers. Then you can repair/replace the required parts without the fluid in the way.
I would also recommend the you replace the PTO seal and O-ring seal if needed at this time and replace the inspection plate gaskets. The inspection plate gaskets are fairly easy to cut yourself if you need to.
Open the drains one at a time to handle the gush of fluid. Once you have gone through all of them open them all up again with a pan under each and let it drip at least over night. Make sure your lift control is in the down position to drain the piston.
You should plan on "washing/Flushing" out the inside. Particularly if you have water in the oil... i.e. if brown/milky. To wash the inside use either kerosene or diesel. I put mine in a garden sprayer and sprayed the insides down. I put the garden sprayer nozzle everywhere I can, up the PTO shaft opening, if you pulled it. Through the Filler hole, through the inspection ports, through each drain plug. I catch the diesel in clean oil pans let it settle then decant the "clean" fluid off the sludge and spray again, and again. Go have a beer and let it drain. I then wipe out the bottom with clean paper towels to get the crud out. (do not use cheap towels here you do not want them falling apart). If your fluid had water in it, the "Milky" oil will continue to appear for a while, I just came back and wiped it out again, and again util gone.
This is a good time to do other maintenance. Grease the fittings, Pull the air filter and clean it.
Be sure to do the diesel flush with good ventilation. The fumes are powerful.
Button her back up with your new seals and fill. Toward the end fill slowly... i.e. quart or 1/2 liter per 5 to 10 minutes. To let it all even out in the sumps. The first time I changed the oil I did not do this and I over filled by a gallon and a half. And because I did not wash out the back that gallon and a half was now water contaminated and useless.
You will be glad you did this when it is done.
Jeff
SandyB@TN
01-07-2006 10:28:07
Grimme,
Directly below the the seat, on the right-hand side, you will find a dip stick. That's where you check the transmission fluid level. Just to the left of the gearshift, you will find the fill-hole cover. Uscrew this and you can add tranny lube. There are two drains for the transmission and the differential housing. They are at the bottom of the transmission housing and the differntial housing on the left hand side. If when you check the fluid level, the lube has a light brown, milky color, the lube is water contaminated and needs to be changed. You have to open both drains to do this...not necessarily at the same time. Hope this gets you started.
