Ferguson Tractor
Mike J Taylor
01-02-2006 21:45:57
Hi - I have recently purchased a Ferguson tractor model number A113559 here in New Zealand. I think it is a TEA series 20. Can someone let me know its age and model, horsepower etc.
Also the oil pressure is 80 psi cold and drops to 20 psi when warm - is this OK?
Regards Mike Taylor
John (UK)
01-05-2006 10:30:05
 Re: Ferguson Tractor in reply to Mike J Taylor, 01-02-2006 21:45:57
The model is a TEA made in 1949 and it is 23.9hp
The oil pressure is getting low when hot but try changing to a slightly heavier grade if the weather is hot. The cause will be a little wear in the crank bearings and possibly the oil pump too, but nothing to bother about yet. make sure you keep the oil and oil filter changed regularly.
Jeff-oh
01-03-2006 11:01:56
Based on that SN you have a 1949 TEA-20. The HP is around 22 HP.
Jeff
Paul F B
01-04-2006 08:12:14
 Re: Ferguson Tractor in reply to Jeff-oh, 01-03-2006 11:01:56
Mike; My tractor runs about the same as far as oil pressure. It has been very dependable with no problems noted. I did go to a heavier weight oil in the summer to keep the pressure up. You will love the little fergie. Paul f B
