TO 35
max pfrimmer
01-02-2006 15:54:27
I just got a to35 gas that backfires (pops) every 10 seconds or so. Yhe guy I got it from thinks it is a valve spring. Is there a thread on here that shows how to remove the head with out removing the engine?
gerard
01-03-2006 20:44:23
 Re: TO 35 in reply to max pfrimmer, 01-02-2006 15:54:27
You don't have to take a head off to change a valve spring. Just make sure the piston of the cyl you're working on is at TDC so you don't drop the valve in, then either hold valve up with a tool or compressed air whilst you change the spring.
steve19438
01-03-2006 15:22:33
not trying to a wiseguy but make sure you drain the fuel tank first!
George in Spokane
01-03-2006 12:52:49
Removing the head is very simple. Just take of the gas tank and the valve cover. The head just unbolts.
It takes about 15 minutes.
Max Pfrimmer
01-04-2006 06:38:48
 Re: TO 35 in reply to George in Spokane, 01-03-2006 12:52:49
Thanks, sounds easy and I can't wait until this weekend to get my hands dirty. Does it sound like it could be a broken valve spring? Is there a better head gasket out there and should I use a sealer also? Thanks Max from KC
John (UK)
01-05-2006 10:51:00
 Re: TO 35 in reply to Max Pfrimmer, 01-04-2006 06:38:48
No need to take the head off as Gerard says. Make sure that the clearances on the valves are correct and that one of the caps on one of the valve stems hasn't come off.
