to-30 Brake locking up in reverse
Paul (FLA)
01-02-2006 07:22:15
one wheel is locking up when I drive in reverse. It does not happen all the time. Any thoughts?
Paul
John (UK)
01-02-2006 08:12:52
 Re: to-30 Brake locking up in reverse in reply to Paul (FLA), 01-02-2006 07:22:15
Usually that means the brake shoe springs are fitted incorrectly.Top one should be black, bottom one should be blue. The brakes are self-energising (going forward)and if the springs are fitted incorrectly this can't happen, so it will work in reverse. Is the brake linkage free, try LIFTING each independent brake pedal, if the rod along the transmission case bends then the joint at the end of the independent brake pedal is seized up and it will never work until you have them free. If you need info. about resetting the brake linkage to remove all the free play, email me at:-
fergusontractors (at) tiscali.co.uk
and tell me what the problem is and what you need.
