Torque specificationsTO-20
Jim L (MN)
01-01-2006 08:40:36
What are the torque specifications on the head and rocker arms of a TO-20.
Thanks
gshadel
01-03-2006 05:11:49
 Re: Torque specificationsTO-20 in reply to Jim L (MN), 01-01-2006 08:40:36
I don't have a torque for the rocker arm mounts either. If none are listed, you should assume the standard grade 3 torque. If memory serves me right, the mounts are aluminum and prone to crack if over-torqued.
I have a nice torque chart for standard torque for grade 3,5,&8 bolts that I found on the internet, but I don't recall the bolt size, thread pattern on those bolts.
If you need the torque, post a new post with the bolt size, and if it is course or fine thread, I'll let you know.
Jerry/MT
01-01-2006 19:13:16
Cylinder head torque 70-75 ft-lb. I can't find a spec for the rocker arm.
