Sure Seals for TE20
dfitch
12-31-2005 05:42:08
On a previous post I was advised to use Sure Seals to stop leaking in rear axel on TE20 serial number 21052. I have been to every internet parts place I can find and Sure Seals are only listed for TO20. No one has them listed for TE20. Has anyone actually installed Sure Seals on a TE20 and if so where can I obtain them
Dennis P in Ohio
01-01-2006 10:02:46
 Re: Sure Seals for TE20 in reply to dfitch, 12-31-2005 05:42:08
A word of caution: I tried one of these on my TE 20 and the leak was just as bad as before. Upon disassembly, I discovered the rubber seal was not contacting the shaft very well, so the oil just went right on through. I wound up having the regular seal installed. I suggest you be certain there is good contact there.
cheif
01-01-2006 06:39:04
I had sure seals on my 20 and they leaked badly. it seems to me when they eventually leak the oil is trapped in the outer bearing until the chamber is full thus increasing the tendancy for the outer seals to leak. Make sense?? If you do install them wouldn't you have to pack the bearings in grease/ I know it is reccomended on my F40 because there is no way for oil to get to them. Happy new year and thank you to all who contribute to this forum. I sure have learned a lot!!
gshadel
12-31-2005 18:23:18
I picked up sure seals on Ebay a couple months back. In fact, I'm installing them this weekend. I pulled the axles on my TO-20 today. There are sure seals on them now. I'll be prying off the old seals and installing the new seals tomorrow!
George
John (UK)
12-31-2005 13:33:28
The seals for a TO20 will fit a TE20, they are the same part for both tractors.
