Oil level in air cleaner
Dennis P in Ohi
12-29-2005 17:09:55
Please can someone clarify where the oil level should be in the air cleaner reservoir?
The cup (as I call it) has no markings, but it does have a crease in the metal all around, but I am not sure if this indicates where the level should be. Also, the cup has an inner ring; should I fill the whole cup to the top of this inner ring?
I guess I am showing my ignorance here, bit I need to be sure so I don't overfill.
Thanks to all.
Michael Campbell
01-02-2006 13:33:10
 Re: Oil level in air cleaner in reply to Dennis P in Ohio, 12-29-2005 17:09:55
In regards to the air cleaner, could you tell me how to remove the mesh(for cleaning), I can't see how it comes apart and I don't believe that in that day (1953) they would use and throw away a entire metal unit! Any help on this would be great.
John (UK)
01-02-2006 13:59:32
 Re: Oil level in air cleaner in reply to Michael Campbell, 01-02-2006 13:33:10
It doesn't come apart, you remove the cleaner from the tractor and immerse it in a bucket of Gas or TVO (depends which side of the pond you are for that.)(not diesel as it is too oily), and leave it overnight. This softens the dirt and will wash out just rinsing it or using a hose, then allow it to drip dry, this should be done about twice a year.
John (UK)
12-31-2005 14:03:39
It should be filled to that "crease" that you mention, it holds 3/4 imp. pint.Use the same oil that is in the engine. It is called a "cup" or a "bowl" depending on where you come from. No need to fill it anymore than the "crease" as it draws the oil up-wards into this filter when the engine is running.
DennisPinOhio
01-01-2006 09:53:06
 Re: Oil level in air cleaner in reply to John (UK), 12-31-2005 14:03:39
I appreciate the information.
Have a happy and prosperouis New Year.
gerard
12-29-2005 17:18:00
Should be an arrow pointing to that crease you mention.
Dennis P in Ohio
12-30-2005 05:52:11
 Re: Oil level in air cleaner in reply to gerard, 12-29-2005 17:18:00
Thanks...but there"s no arrow.
should the intake down-tube be immersed in the oil?
gerard
12-30-2005 15:42:21
 Re: Oil level in air cleaner in reply to Dennis P in Ohio, 12-30-2005 05:52:11
Couldn't say without going to shed to take a look. Provided 'mud' that collects in bottom is cleaned out regularly & oil refilled to crimp line (about same level as inner holes), it'll be right. It's designed so oil is drawn up to lubricate mesh, whilst larger particles of dirt head straight into oil.
