ZANG THANG
tombo
08-15-2000 19:44:06
How does one get a Zang Thang? Seems like a must have device
BillMc
08-15-2000 20:11:48
 Re: ZANG THANG in reply to tombo, 08-15-2000 19:44:06
Here is zane's page. Buy one you will love it!!
Bill Mc
Billy
08-15-2000 20:05:43
It ain't no Zang Thang, it's a Zane Thang. Go to>Link
It>Link only costs 80 bucks. If you already have draft control you don't need it.
BillMc
08-15-2000 20:18:03
 Re: Re: ZANG THANG in reply to Billy, 08-15-2000 20:05:43
If you have POSITION CONTROL you do not need it!!
TO-20 ,TO-30 ,9n ,2n only have draft control. The 8n has position and draft control.
Bill Mc
Rick Ferguson
08-16-2000 09:46:34
 Re: Re: Re: ZANG THANG in reply to BillMc, 08-15-2000 20:18:03
I have a '50 TO-20. it has "weak" hydraulics and has to be constantly tweaked. what is the difference between draft and position controls and what does this tractor have. Would I benefit from a Zane Thang or do I even need one? thanks Ferg
Bill Mc
08-16-2000 20:27:47
 Re: Re: Re: Re: ZANG THANG in reply to Rick Ferguson, 08-16-2000 09:46:34
Hi Rick I also have a 1950 TO-20. My fergy has a strong hydraulic pump but the lift cylinder leaks down rather fast (about 2 min with a 250 lb load).The TO-20 has draft control only. Draft control is used mostly for plowing. The top link spring controls the depth of the plow. If the plow goes too deep, the pressure on the top link spring raises the 3 point hitch untile the pressure is relieved. A tractor with position control can set the 3 point hitch in any position and it will stay put(position of the 3 point hitch is realitive to the position of the touch control lever).WOW that was long!! Yes you will absolutely benefit from a zanethang!! I have one, it makes blading and grading a pleasure. If you have any doubt check the archives and email zane himself.
Rick Ferguson
08-17-2000 06:09:42
 Re: Re: Re: Re: Re: ZANG THANG in reply to Bill Mc, 08-16-2000 20:27:47
thank you sir fer the help! I've been reading all the articles on the "thang". sounds like I should sign on the dotted line!! all you guys are a great help
