to-20 3-point hitch
jim sandlin
12-21-2005 17:20:01
i recently purchased this tractor, the previous owner had changed all fluids, but now the 3-point arms won't raise after it was sitting for a couple months. any ideas what i should look for first? fluid is not low. thanks for any suggestions
Martin minn
12-22-2005 03:43:40
 Re: to-20 3-point hitch in reply to jim sandlin, 12-21-2005 17:20:01
You might want to check the fluid level if you haven't done this
j2
12-21-2005 17:34:44
Is the PTO(&hydraulics) engaged? (little lever on the left side of gear case below your seat) And the PTO/hydraulics only works when the clutch is engaged too... i.e. best to put in neutral first.. If nothing is working now, get back to forum for further help. If you want visual indicaiton of the PTO & Pump working, look at the PTO shaft (remove the cover if it has one). If it is turning, then the pump should be working too..
John (UK)
12-22-2005 10:17:42
 Re: to-20 3-point hitch in reply to j2, 12-21-2005 17:34:44
Check what you have already been told by the others and if it still doesn't work, remove one of the round covers from the housing under the seat. There is a long Control fork hanging down from the top which disappears into the oil, when you move the control lever on right side, this fork should move back-wards and forwards, most likely it is this that has stuck. so with the engine running and the PTO in gear gently try to move the long fork back-wards and forwards, the travel will be a couple of inches. DON'T PUT YOUR HANDS INSIDE IF THE ENGINE IS RUNNING. If that doesn't cure it, post here again or email direct to:-
fergusontractors (at) tiscali.co.uk
and explain what it is doing and what you have tried and I will send you some written information and pictures so you know what you are trying to do....John
