Z120 Continental Cracks
Steve Munger
12-19-2005 10:03:33
I am rebuilding a Z120 Continental engine and found that the block is cracked between the cylinders in the center both top and bottom. I have been told that this is a common thing with this engine. To get it fixed is about $600.00 to $750.00 or should I try to find a block that is good. What is the best way to go and where could I find a good block.
Thanks
Jerry/MT
12-19-2005 20:44:22
 Re: Z120 Continental Cracks in reply to Steve Munger, 12-19-2005 10:03:33
This is common on Contientals when they have been overheated.You can have a machine shop furnace braze the block and it will be as good as new.I have a remanufactured engine in my -30 and it was furnace brazed and it runs like a top. The process actually stress relieves the block and then it is remachined to proper dimensions.
dozerman
12-19-2005 10:16:33
Call Pittsburg Tractor in Pittsburg Texas. They have used good, not repaired, and not cracked blocks for $550.00.
