T.O.-30 PROOFMETER OR TACH
guyeli
12-11-2005 12:24:56
am looking for a source of info on installing and purchasing a proofmeter or MF-TYPE TACHOMETER for TO-30.
Tom H.
12-15-2005 06:34:31
 Re: T.O.-30 PROOFMETER OR TACH in reply to guyeli, 12-11-2005 12:24:56
On my TO30 there is a 6 volt clock style Hobbs meter that record time not revs. I found a replacement (the original was smashed and rusted out) on ebay.
To30
12-11-2005 18:16:10
I have one on my To30 it mounts on the steering colum two bolt on the right side on a mount that come with the tack it drives off the back of the generator .I dont know where you can get one ,I found mine at a swap meet for $30.00 .Good Luck
Jerry/MT
12-11-2005 16:17:59
I don't think they were offered as an option on the TO-30, but I could be wrong. I have never seen one, but then again I can't say I've seen every TO-30 made! The TO-35 had one and it was driven off the back side of the generator I believe. I suppose you could find one off a TO-35 (generator, gauge, and drive cable,etc)and swap it over to your TO-30. I'm not sure that the ground speed will be correct for the TO-30 because the tranny and final drive ratios are not the same. IF the generator drive pulley and the crankshaft pulley are the same betwen the -30 and the -35, then the rpm will be right as will the hour meter.
