TO20 IDLE LINKAGE
terry knaus
08-12-2000 18:23:40
ANYBODY KNOW HOW TO GET THE TENSION BACK IN THE LONG ROD THAT CONTROLES THE RPM,S,THERE'S A SPRING ON THE END NEAREST THE STEERINGWHEEL AND I CANT SEEM TO GET THE RIGHT TENSION TO PREVENT THE IDLE FROM GOING UP,THANKS FOR THE HELP
jagries
08-14-2000 10:11:07
 Re: TO20 IDLE LINKAGE in reply to terry knaus, 08-12-2000 18:23:40
I agree with Sandy, you probably need a new friction disk. If you need to run now, as a temporary measure, a hack saw blade between the disk and the metal wall will do the trick. This however is not a permanent fix.
Good luck
Fred OH
08-14-2000 10:10:42
I think if I remember right, all it amounts to is a piece of flat cork less than 1/8" thick. Go to a parts house and acquire some and cut it out to fit and glue it on with contact cement. Reassemble and should be okay, if not, tighten spring as you did previously. L8R----Fred
SandyB@TN
08-13-2000 11:53:30
Terry,
Sounds like you need a new friction disk. It goes between the round, flat part of the throttle rod and the firewall of the tractor. They wear out after 50 years or so. Check your service manual. You do have a service manual, don't you? If not, you need one.
HTH
Sandy
