te 30 number 4 not firing
greg5555
12-08-2005 18:37:40
working on a te 30 and number 4 cylinder is not firing. heres what I have done so far:
check compression all cylinders 120psi
check spark, good and strong at wire and plug, replaced plugs
pull all plugs except for number 4, will fire for 5 seconds, only with full choke.
pulled all plugs except for number 1 and runs fine (fine for only one cylinder)
run good on three cylinders, don't believe spark is the problem. any ideas??
greg5555
12-14-2005 08:31:25
 Re: te 30 number 4 not firing in reply to greg5555, 12-08-2005 18:37:40
found the lock nut on the intake valve adjuster screw came undone and valve was not opening.
Ed H.-OH
12-10-2005 11:58:07
Hello, Several times in my life I have run into plugs that tested good but wouldn't fire in the cylinder under compression ( Replace the Plug or swap with another cylinder to test). Also a coupple of times i've found a bad wire to the cylinder causing it to test good but not fire when running. The most recent was a doge van, It would run on all 4 idling and under light load ,but would miss under hi power-It was the wire. -My 2 cents worth- hope this helps-good luck.
LM in Tx.
12-08-2005 22:32:55
Sounds like valves. Possible stuck intake valve, broken push rod, or a broken/backed off valve adjuster. Good compression indicates the valve is closed during the compression stroke but having to fully choke it to get fuel to it would tell me that it may not be opening. I guess it could also be sucking air at the manifold gasket - may check for loose bolts. Hopefully its the adjuster or manifold gasket or something simple that wouldn't require removing the head and having the valves done. Hope this helps. LM
