What size piston in the TO35 lift cylinder?
Dave in CA
12-07-2005 19:48:21
I have a '59 TO35 and I am going to re-ring the hydraulic lift cylinder. I have not taken the lift cover off yet and have conflicting info as to the size of the lift cylinder piston.
Is it 2 1/2" or 3"? Thanks,
Dave
Dave in CA
12-09-2005 18:48:06
 Re: What size piston in the TO35 lift cylinder? in reply to Dave in CA, 12-07-2005 19:48:21
Thanks guys.
I appreciate the responses.
Dave
George S. in the real NY
12-09-2005 18:22:01
Got one of those apart now, mine is a late '55. It has the 2 1/2" piston. According to the parts list, that was used prior to sn 179304. Also, at the sn break there were many changes to the hydro pump, enough so that there are separate diagrams and lists in the parts catalog. Also the psi of the relief valve changed from 2000 to 3000. Your tractor should have all the later parts. HTH, GS
jerrycpp
12-08-2005 12:47:56
You might consider taking the old piston to a hydraulic cylinder repair shop. They can turn out the top and second groove to use an "O" ring and backup washer. Be sure to put the old rings back in whatever grooves are left. This is a far better cure than just replacing the old rings.
John (UK)
12-08-2005 05:38:32
It was originally 2-2/2" then modified to 3" but in 1959 it was most likely 3"
