to20 trottle wont adjust
weim
12-07-2005 16:40:06
I'm new to tractors I just picked up a to-20, the throttle seams to be stuck at idle, I can move the throttle lever back and forth but the rpms only change about 200 rpms from idle to wot. the trottle was working fine until it warmed up today I haven't done anything yet but the throttle rod is conected and appears to be moving any ideas?
Dennis P in Ohio
12-08-2005 06:23:54
 Re: to20 trottle wont adjust in reply to weim, 12-07-2005 16:40:06
Happened to me once. Look under the dashboard where you"ll see a connection which is a ball in socket type. make sure it"s hooked up.
Let us know what you find.
weim
12-08-2005 15:59:21
 Re: to20 trottle wont adjust in reply to Dennis P in Ohio, 12-08-2005 06:23:54
all the linkage is connected and moving, I gave the carb a few taps with a rubber hammer now it is working ok so it looks like its time to rebuild the carb?
Jerry/MT
12-07-2005 18:33:44
Your linkage needs adjustment most likely. Get yourself a Ferguson Shop Manual for the instructions or wait for John(UK) to answer this. He has some instructions he can email to you.
