TO-35 Hydraulic Lift adjustment
Greg in MS
12-05-2005 17:55:24
I am having trouble adjusting the lift height on my TO-35. I have replaced the original 2.5 inch lift cylinder with a 3 inch cylinder. Regardless of the adjustments I make in the guide rod spring tension, I cannot make the verticle control lever go back far enough to raise the lift the proper amount. I assume that the Lever support bracket is slightly forward of where it was before. Has anyone run into this problem? That I see, there are two fixes, one is to re-drill the mounting holes in the lever support bracket and move it back about 3/8 of and inch (this may cause issues with the linkages), or add about 3/8 inch of width to the end of the verticle control levers. If anyone has had this problem and solved it, please let me know.
John (UK)
12-06-2005 10:42:07
 Re: TO-35 Hydraulic Lift adjustment in reply to Greg in MS, 12-05-2005 17:55:24
Personally I have never had this problem and I have been able to set them up OK. Maybe you should have a word with Big Dean:- Link
John (UK)
12-06-2005 10:39:00
Personally I have never had this problem and I have been able to set them up OK. Maybe you should have a word with Big Dean:- Daustin62 (at) aol.com
