oil for TO 30 transmission/system
Matt Jirgens
12-05-2005 17:29:32
Hello,
I recently bought a TO-30, I think 1952 model, and am wanting to change all of the fluids on it as I don't know when it was done last. The manuel says to use 80-90 mineral oil in the transmission,PTO system. Is it still available or is there a modern equivalent which would work better? I live in Kansas and will not be using this tractor during the winter months.
Thanks for your advice.
Matt
D McQueen
12-09-2005 05:34:05
 Re: oil for TO 30 transmission/system in reply to Matt Jirgens, 12-05-2005 17:29:32
I have used John Deere transmission and hydraulic oil in mine for years now. Works great especially in winter and I have had no problems whatsoever.
Don M
John (UK)
12-06-2005 03:45:48
You can safely use 15W-30 Multi-grade in there too, that should be easier to find.
Glenn/Calif
12-05-2005 19:12:47
Matt:
The transmision/differential/PTO system oil is GL1 mineral oil, 80-90 wt in the summer. If you have a NAPA Auto Parts Store in your area, the NAPA P/N is 65-205. Do not use any other gear lub. GL1 has no additives and is the same as the original. The yellow metal parts in your system will not tolerate any of the other "GL" numbers, only GL1. There are other places that carry the GL1 Gear Lub but, several of us have found NAPA to be the least expensive. LOL.
Glenn
