MY TO 20 WONT CRANK
terry knaus
08-11-2000 15:45:09
hello,
just redid the lower end of my tractor(turn crank &new berrings) and had the flywheel geer turned around and had new brushes and bushing put in the starter and new battery,now the dang thing wont crank??i was wondering if there was some kind of spacer for the starter like if its to close to the flywheel,since i turned that gear its like having a new flywheel,any help would be greatly appriciated thanks
Mike
08-11-2000 17:31:12
 Re: MY TO 20 WONT CRANK in reply to terry knaus, 08-11-2000 15:45:09
Terry, if you can clarify for me, can you rotate the engine with the hand crank? or the belt, the point is, is the engine too tight or were you able to rotate before the final bolt up? If you had good rotation before final assy and good rotation before the starter install, then you need to look at the starter end. If the engine is too tight and would not rotate before it will not move with the starter. good luck and keep us informed. Mike
terry knaus
08-12-2000 12:06:11
 Re: Re: MY TO 20 WONT CRANK in reply to Mike, 08-11-2000 17:31:12
YES I CAN ROTATE THE ENGINE BY HAND,BUT IT SEEMS LIKE THE STARTER IS BINDING,BUT MAYBE IT JUST NEEDS TO BE REBUILT AGAIN THANKS FOR THE INFO
Mike
08-12-2000 18:26:20
 Re: Re: Re: MY TO 20 WONT CRANK in reply to terry knaus, 08-12-2000 12:06:11
Terry, now that you have isolated to the starter I agree, take it back to the shop that rebuilt it. Have them verify that it does indeed work. My TO20 has no shims for mounting. If it works for them...are you 6 or 12 volt? Could you be having a voltage/current loss? good luck Mike
terry knaus
08-12-2000 18:30:42
 Re: Re: Re: Re: MY TO 20 WONT CRANK in reply to Mike, 08-12-2000 18:26:20
thanks for the help,i finally got it to crank well see if it continues to do so,i need a new starter button thats for sure .thanks
