serial number
Clayton Case
12-04-2005 18:25:59
I just bought a Ferguson and after e-mailing a few sites with no reponse back maybe some one can help me. My serial # is 25056, is this a 1950 model T20. And also on left side of steering column is the numbers TO3551, what are they?
Jeff-oh
12-05-2005 09:12:26
 Re: serial number in reply to Clayton Case, 12-04-2005 18:25:59
The serial number 25056 would indicate a 1950 TO-20.
The TO3551 number is a casting part number.
The serial number is located on a data plate infront of the steering column on the dash. The SN should be proceded by TO.
Jeff
Dennis P in Ohio
12-05-2005 05:58:37
Your tractor # TO3551 is a 1949. That year, the numbers started at 1808 and in 1950, they started at 14660. You may verify this by looking under Research & Info on this page, at the left side. Click on Serial Numbers and follow the prompts.
Clayton Case
12-05-2005 13:13:37
 Re: serial number in reply to Dennis P in Ohio, 12-05-2005 05:58:37
Maybe I screwed up here, I am getting 2 differnt years, The numbers25056 are on the metal tag above steering wheel and it has the word serial before them, the # TO 3551 is cast into the steering column.
Thanks guys I appreciate the help but what year is right...1950 or 1949?
Jerry/MT
12-05-2005 14:09:11
 Re: serial number in reply to Clayton Case, 12-05-2005 13:13:37
The year that goes with the serial number above the steering wheel. Look in the Research& Info Section under Serial Numbers on the left side of this page.
