Harry Ferguson
Deldot
12-04-2005 17:57:42
I just recently bought a TO 20, and don't know anything about it. I would like to know when it was manufactured. The Ser# is TO 86245, 4 cyl. gas, 4 speed & reverse.
Starts a little contrary but runs well.
Seal for PTO seams to be leaking.
Thanks
Daniel
Jerry/MT
12-04-2005 18:10:43
 Re: Harry Ferguson in reply to Deldot, 12-04-2005 17:57:42
With that serial number it's a TO-30 not a TO-20. It's probably a 1951. You can find the year by going to the Research & Info section on the left side of this page and click on Serial Numbers and find it under Ferguson. If the engine has an oil filter on the right hand side, it's for sure a TO-30. If the engine data plate is still on it (LHS by the distributor) and it says Z129, it's a TO-30. Regarding the starting, it may need a tune up. Leaking PTO seals on a 50 + year old tractor is common and an easy fix. Does it have a 1-1/8" PTO shaft? If it does you might want to consider changing it to the industry standard of 1-3/8 ". For about $100 + you can get the 1-3/8 " shaft with new bearing and seal and it's and easy swap as long as the existing shaft is not internally damaged.
