to30 transmission pops out
Kim Ball
12-04-2005 05:57:56
I have to30 the transmission keeps poping out of gear. Can anyone tell me what is going on with the transmission and what it takes to fix the transmission thank you.
John (UK)
12-06-2005 08:54:16
 Re: to30 transmission pops out in reply to Kim Ball , 12-04-2005 05:57:56
Take the top of the gearbox off first and check the plungers and springs don't split the tractor before checking them. If they are ok you can either fit new springs or shim the old one that is jumping out to give it more pressure. If that doesn't cure it,possibly worn teeth on the sliding couplings, worn selector fork faces or maybe even bent fork so not pushing it into gear fully. Or incorrect pre-load on main or counter-shaft in box.
mike2
12-04-2005 10:35:42
Which gear(s)? When does it kick our (under load)? Is it random or repeatable? Is there any grinding when this happens?
Kim Ball
12-04-2005 16:38:36
 Re: to30 transmission pops out in reply to mike2, 12-04-2005 10:35:42
when under load and going up incline does not grind it pops out more in 1st 2nd grear
Mike2
12-04-2005 18:04:21
 Re: to30 transmission pops out in reply to Kim Ball, 12-04-2005 16:38:36
Well, here is my thoughts. Since it is popping out of gear on both the upper side (1,3) and the lower side (2,4) it does not sound like it is a torque or sync problem. I has a similar problem on a smaller tractor, not my to-30. What happened was a spring loaded ball bearing was used to hold a groved cam in place. The cam rotated with the shifting of gears. Anyways, the spring itself colapsed (broke in the middle) which allowed no tension on the cam and it would rotate whenever it wanted. I had to split the entire transaxle to just replace this little spring. Keep in mind, this was not on my large ferguson, but the operating parameters should be similar. So do some more research befor splitting.
kim ball
12-05-2005 16:27:18
 Re: to30 transmission pops out in reply to Mike2, 12-04-2005 18:04:21
Thank you mike for your thoughts I think you are right about spliting the tractor.
