TO-20 Distributor Question
Tim Tenn.
12-02-2005 14:30:59
I odered a new replacement distrbutor from this site. I just received it. It has a differant cap and rotor and no dust cover like my old one. It looks like the same cap used on a 8N ford. I haven't pulled my old one yet, but it looks like the housing and shaft are about the same. It may just be a replacment, problem is I installed electronic conversion on my old one and I don't know if it will fit this one. I thought I would ask if anyone has tried this before I started tearing things apart.
Tim Tenn.
12-02-2005 17:07:21
 Re: TO-20 Distributor Question in reply to Tim Tenn., 12-02-2005 14:30:59
Well I will save you all the trouble of responding to this. After I posted this I called yesterdays tractor parts to make sure this was the correct part and it was. It is a new distributor made by tisco. It replaces the original. It uses the same cap, rotor, points and condenser as a late model 8N Ford. The electronic ignition from the original distributor won't work. If I want to use electronic convertion with the new one I'll have to purchase another one. I did install it and It runs perfect. I have another tractor I can use the electronic ignition on, so it won't be a loss. I thought I would share this information, just incase some one else tries to do this.
wayne2
12-02-2005 17:54:21
 Re: TO-20 Distributor Question in reply to Tim Tenn., 12-02-2005 17:07:21
Thanks for info!! know if we're only able to retain it or smart enough! sorry not alot of brain cells left. LOL W
