8N DRAINING BATTERY
NICK D
12-01-2005 09:18:59
I just got a 1949 8N with front mount distributer. The battery will discharge overnight if I leave the battery cables attached. It has been converted to 12v with a Delco 1-wire alternator. There is a jumper wire from the Alternator terminal to one of the spade plugs on the face of the alternator. I am not sure what this is for. What should I look for first?
LPgasonly
12-01-2005 10:50:35
 Re: 8N DRAINING BATTERY in reply to NICK D, 12-01-2005 09:18:59
After you shut it off, take a piece of metal like a wrench or something and put it on the alt pulley. If it is magnetic, the alt is staying energiezed. You need to fix that little wire you were talking about or the switch itself. Un-hook your battery and see if it goes dead. If it does, it is a bad battery. Good luck
Jetman8N
12-01-2005 10:09:53
Nick,
I'd post this on the Ford 8N forum and ask for Dell. He or one of quite a few other electrical types will have the answer as well as a little humor for the situation.
NICK D
12-01-2005 10:15:29
 Re: 8N DRAINING BATTERY in reply to Jetman8N, 12-01-2005 10:09:53
Sorry, I was jumping around and forgot where I was.
