TO20 conversion to 12 volt
Ron Lindquist
11-28-2005 16:27:40
Don"t see any kit for TO20,Does anyone know where to get one or if the Ford 8NE10300ALT-C listed in this sites parts, will work ?
Thanks,
Ron
John (UK)
12-01-2005 06:55:04
 Re: TO20 conversion to 12 volt in reply to Ron Lindquist, 11-28-2005 16:27:40
As Paul says it is the same as a TO30 its just the mounting bracket for the alternator that will cause problems but should be easy to make one up.
Paul in Ms
12-01-2005 04:05:20
Take a look in the archives. This has been discussed many times . The to -20 does not a 12 volt kit. The problem is the bracket. You could get a kit for a to-30 and make your own bracket. I ordered a wiring kit and a wide pulley from Genessee products and a 1970 alternator from the auto supply. I then made the bracket from some scrap steel. Works great. Try www.genesseeproducts.com or 918-274-8000
Ron Lindquist
12-04-2005 07:07:01
 Re: TO20 conversion to 12 volt in reply to Paul in Ms, 12-01-2005 04:05:20
Thanks, Had looked in archives but everything is about the bracket not fitting~~~Appreciate your info. as to where to get parts and that I will have to make a brk"t.
To cold and snowy out to do anything but sit by the fire and plan !
Dennis P in Ohio
11-29-2005 06:06:13
I suggest you try your local Massey Ferguson dealer. If they are like my local one, they'll sell you all the parts and a diagram for rewiring.
