Busted Stater Nose Cone
Yseesee
11-27-2005 06:00:19
third party image
I was just bragging to my father how well the tractor started the other day when it was 18 degrees out in the morning. Today I was splitting wood with the Unicorn Log Splitter for about 3 hours and I shut her down. I loaded up the trailer and I brought the wood to the woodshed and unloaded it. I then jumped back on the Fergy and hit the starter and I heard a strange sound so I released the starter. I hit the starter again and nothing, no sound at all! The amp gauge jumped to the negative side but that was it. I pulled the starter and this is what I found. I replaced this starter about two year ago because the same thing happened. Anybody have a hand crank?? These starters aren�t cheap!!!!! I've seen posts on Shims??? Timing??? Not sure what the correct answer is...
Gregg/Ohio
11-30-2005 20:59:15
 Re: Busted Stater Nose Cone in reply to Yseesee, 11-27-2005 06:00:19
How many engine rpm do you have to have to run this item? Does the TO-35 have enough horsepower to do a good job at spliting the logs? Does it stall engine sometimes? Thanks!
Yseesee
12-01-2005 05:41:50
 Re: Busted Stater Nose Cone in reply to Gregg/Ohio, 11-30-2005 20:59:15
The splitter seems to work fine @ idle speed or a little bit above idle (not sure what the RPM is). I�m not splitting really large pieces of wood nothing larger than 24� across and the pieces are normally 16� to 18� long. I split wood with this splitter for 4 hours and there were only two times that it actually killed the tractor. I just had to bump the throttle up a bit after it was restarted and it split it without any problems. I�m using a TO30 so I�m sure the TO35 can handle it.
Gregg/Ohio
12-01-2005 20:07:35
 Re: Busted Stater Nose Cone in reply to Yseesee, 12-01-2005 05:41:50
Thanks for the infromation Yseesee, you have been helpful.
jerrycpp
11-28-2005 07:10:32
The most common cause of a broken nose housing is someone didn't let the starter wind down completely before trying again, or hitting the start button while the engine was kicking back from a non-start. Let everything stop moving before hitting the starter button (or pushing the gearshift to start) and you'll not have this problem again. Good luck!
Crem
11-28-2005 19:42:32
 Re: Busted Stater Nose Cone in reply to jerrycpp, 11-28-2005 07:10:32
I believe that you are right about the broken nose cones happening from not letting the starter coming to a complete stop before trying again. We broke a couple of them on a TO-20 back on the farm in the 1960's. I still have the same tractor and notice that if I get in a hurry when it doesn't fire and hit the starter again before it has completely stopped, it will bang pretty hard.
Yseesee
11-27-2005 06:14:53
third party image
Just in case there were any questions about the Unicorn Log Splitter I decided to add the picture to the Implements Photo Page.
Dennis P in Ohio
11-27-2005 07:26:22
 Re: Busted Stater Nose Cone in reply to Yseesee, 11-27-2005 06:14:53
That log splitter looks like something I could use. I cannot afford a regular one, so can you tell us how this one works....and is it still available? Price? Source(s)?
Thanks.
Yseesee
11-27-2005 14:34:39
 Re: Busted Stater Nose Cone in reply to Dennis P in Ohio, 11-27-2005 07:26:22
third party image
Dennis, I'm not sure if this is available anymore or not. I found it in the woods at my brother-in-laws and I decided to clean it up and give it a try. After a little trial and error I figured it out. It basically uses the PTO to spin the large cone shaped splitter. As you push the piece of wood into the tip the tip starts drilling into the wood. That�s when you let go and it does the rest. I found out the hard way the you want the lower part of the wood to rest on the rod that is running parallel to the cone. If you don�t the thing will spin the hunk of wood around as fast as the PTO is turning, if that happens you better get out of the way. Once I figured that crucial bit of information out it was a piece of cake! Here is another shot.
