starter
don sullivan
11-27-2005 04:46:18
think the ferguson is TO20 can I put a 12volt starter on in stead of the 6 where do i get one reasonable tractor serial 96566 broke on starter already does not want to start rebuilt carburator changed plugs and coil maybe the points? thanks for ant help Sully
phil(va)
11-27-2005 05:42:51
 Re: starter in reply to don sullivan, 11-27-2005 04:46:18
First, the tractor appears to be a '52 TO-30, based on the serial number link on the left side of this page. If it has an external oil filter and the engine numbers begin with 'Z129..." then it definitely is a 30. Next, what voltage is the battery? If it is 12 volts, the original six volt starter should work ok. Not clear to me what the problem is with the starting. Most automotive electrical shops can rebuild these starters cheaper than buying one, if the starter is bad. Again, not clear what your problem is, but if it is turning the engine but not starting first thing to do is isolate whether problem is fuel or spark (or possibly air blockage). Give us more specific info and we'll try to help.
Don Sullivan
11-29-2005 15:21:29
 Re: starter in reply to phil(va), 11-27-2005 05:42:51
Phil thanks a lot for the advice it must be a TO30 because it starts with z129 found a place to rebuild starter it turns tractor over but is very noice it did start but ran very rough thought it was gas rebuilt carburator no better changed the plugs now won"t start has 12 volt battery mabe have to change coil will any 12volt coil work? thanks Sully
