anybody have tsx-485 parts breakdown?
mike2
11-25-2005 15:59:34
Well, I found a used tsx-458 so I can still use the carb kit I had ordered. I have it striped down, but am not sure about a few things. The only carb I am familiar with is the 312 which came off my TO-30 so all I can do is compaire it to that. On the 312, when I removed the main nozzle, there was a jet down there, but I can't find one on the 458, so is there not one? Also, what parts do I pull out of the body when I remove the throttle shaft and carb shaft as in gaskets and stuff. It almost looks like there are two gaskets/o-rings with a brass sleve in between each? Any idea what to remove and what parts come in my kit on order? This whole carb job has been problems, but I am almost done.
Thanks,
Mike
Jerry/MT
11-25-2005 19:45:56
 Re: anybody have tsx-485 parts breakdown? in reply to mike2, 11-25-2005 15:59:34
Mike, the 458 is almost identical to the 312 with the exception of the jets (both idle and main). The venturi size on the 458 is a bit larger. A quick glance down the parts catalog page tells me these are the only differences. My guess is that if you can put the 458 venturi and main nozzle in the 312 body and you can adjust out the differences with the idle and main jet adjusting screws. Whatever you decide to do, make sure that your carb is as clean as a cat's a-- before you assemble it. All new parts won't help if the carb is not thoroughly cleaned out. Blow out the passages with compressed air after you have soaked the whole works in carb cleaner over night and make sure the are all flowing. I use carb cleaner to blow through the passages after I have cleaned it thoroughly as a final check.
Let me know if you have any more questions. Good Luck!
