BURNT TO 30 WHAT YEAR ?
HAZE
11-24-2005 18:16:27
burnt tractor looks exactly like my 52 to 30.the only differance i can see is the 52 has a 7/8 " ignition switch hole on dash and the burnt one has a 5/8 " hole. barn fire claimed most of the steering case and engine plate. i am new to ferguson.
HAZE
11-26-2005 15:15:34
 Re: BURNT TO 30 WHAT YEAR ? in reply to HAZE, 11-24-2005 18:16:27
BOTH TRACTORS HAVE Z129 ENGINE. BURNT ONE IS MISSING ALL I.D. PLATES,THE QUESTION IS, WHAT YEAR IS THE BURNT TO30. WHAT YEAR CAME WITH THE SMALLER IGNITION SWITCH? HAS TO BE A 51 OR A 53 RIGHT? WHATS WITH THE FANCY NUMBERS ON THE SHIFTER PLATE?
John (UK)
11-26-2005 13:08:01
If the plate has gone, look for the engine serial number, between the coil and the distributor. Standard Motors engines had the numbers stamped in the block, Continental engines had a plate with the number stamped in that.
cdmn
11-24-2005 23:30:45
If the plates are melted off, you can still read the casting number on the engine. If it has Z120, it is a TO20, if it has Z129, it is a TO30. The TO20 also has the oil filter up inside the oil pan, not the TO30, I believe. You'll notice quite a few other differences if they are side by side. TO30 was not made in England, but they had differences in their TE20, TEA20, etc.
Jerry/MT
11-24-2005 19:58:33
On the dash just above the steering column is a metal plate with the serial number stamped on it. It'll look like TO-ABCDE. If you can find those numbers, you can go the the Research & Info section on the left side of this forum, click on Serial Numbers and then look in the Ferguson section and find the year.
