TO 30 block
Jason Grooms
11-20-2005 21:23:27
I need a TO 30 block, not because mine is broke between the cylinders but mine has spun mains that are .030 bigger than spec. any help would be appriciated. Thanks, Jason Grooms
gerard
11-21-2005 11:04:38
 Re: TO 30 block in reply to Jason Grooms, 11-20-2005 21:23:27
Do I understand your problem correctly - your mains are .030" undersize (reground crank) but have (presumably after seizing to crank) spun in block?
If so, the only remedy would be to line-bore block "till clean, but I"ve no idea where you"d get bearings oversize on the OD. Ford used to make them for their 2,700 series engines, but they"re the only people who did as far as I know. Never heard of them for Ferguson. As to brazing - that"d be some job! Probably cheaper to cast a new block.
Jerry/MT
11-21-2005 10:46:40
Check with your local auto or industrial machine shop about furnace brazing your block to repair it. If they can't do it they can probably point you at someone who does and you can exchange yours for a remanufactured one or, maybe, if you're willing to wait they can fix yours.
