Zane Thang
Jim
08-06-2000 12:06:37
Could someone explain a little more about what a Zane Thang is? Most of what I've seen in the discussion pages sounds like sales and marketing stuff, like "..attaches with simple tools...", "...ready to use in twenty minutes..", "...works great...". But just what is it? WHERE does it attach? How does it work? I'm not trying to horn in on anybody's patent or copyright; lord knows if I were that clever, I could invent my own thang. Besides, "Jim Thang" doesn't have quite the same ring to it as "Zane Thang". I just like to know a little bit about things before I send my hard-earned money off through the mail. Thanks.
George
08-08-2000 19:23:05
 Re: Zane Thang in reply to Jim, 08-06-2000 12:06:37
Jim, I installed a Zane Thang on my TO-20 one afternoon a few weeks ago while I was drinking a beer and watching my wife try to back-up her truck to hook-up to a trailer. I think I used a couple open end wrenches and pliers. I had the Zane Thang installed before my beer was warm and before the wife had the trailer hooked - up. I was suprised how quick and easy it was. I got the "Thang" because I tore the heck out of my gravel driveway last Winter with a scraper blade. Adjusting the height in snow was a challenge. I pushed as much gravel as I did snow. I also had trouble with my flail mower, it has a really short PTO shaft. If I lifted the mower too high the PTO shaft pulled apart because it is so short. I had a lot of trouble "eyeballing" how high I could lift the mower without pulling the PTO apart. The Zane Thang makes it easy now. I can "tweek" the height of the mower with just a little nudge of the control lever, and it stays there. Oh yea, controlling my scraper blade height is a piece of cake now too. Get the Thang, you will be happy too
Steve W
08-07-2000 12:40:20
The Zane Thang gives you position control. I have a 2N, and don't know much about Fergusons, but Zane says that a Zang Thang works the same on a Ferguson. It's an ingenious invention that even if you saw one, you couldn't make it for as little as it cost to buy.
I really like Zane, and I think most here feel the same, that's why it's hush hush. But being able to raise your bush Hog and have it stay is great, and a lot safer too.
I used to want an 8N, but since I bought a Zane thang, and added an aux tranny, I wouldn't trade my 2N for any 8N.
Take Care
Steve
rege
11-21-2000 12:41:06
 Re: Re: Zane Thang in reply to Steve W, 08-07-2000 12:40:20
Steve; You mentioned an "aux tranny" - what is it? Does it give you live pto?
Jim
08-07-2000 13:21:45
Steve:
Thanks for the reply. The hush-hush is understood, and I'll certainly honor it. I guess my main concern is if this device will solve my problem. I don't know if you've seen any of my other postings, but (and I'll try to keep it brief), I have a Ferguson with a brush hog, and when I raise the lift, before it reaches full height, the drive shaft of the cutter starts grinding on the front edge of the mower deck. Adjustments to the top link, etc. haven't helped. So, I need something that will not only hold at a certain height, but will also limit the amount of lift; that is, stop before the driveshaft starts grinding, and stop there every time even if somebody (like me) absentmindedly keeps tugging on the hydraulic control lever. I guess that's what I really want to know. Think it'll work? Thanks.
Steve W
08-08-2000 11:46:11
 Re: Re: Re: Zane Thang in reply to Jim, 08-07-2000 13:21:45
It won't limit the lift, but it changes the way your control works. Basically your hydraulic control turns into a more typical hydraulic "Centering" valve. You lift, the lift lifts. You let go, it stops. So you are never tempted to lift too high. So it will definatley fix your problem. I used to hammer the universal joints on my HOG. And I used to worry about safety. If you lift it too high, and a univerasl breaks, I think it could be very dangerous....the "Zane Thang" allows you to lift it 6" or a foot and leave it there.
Good Luck Steve
urban
08-07-2000 18:10:48
Jim,
I too dont know much about the zane thing, but I will be ordering one just to obtain level height control - based on the descriptions it should work for you.
However you should be able to raise your bushhog all the way without the shaft hitting the deck - Your centre link should be adjustable in length at the bush hog end or some where else - if not get an adjustable centre link at a farm supply store, when the hog is on the ground make sure that the centre link is screwed down as far as you can get it - this will make the back of the hog raise first, then the front. The down side is that if you have a heavy bush hog, it will make your fergy very difficult to steer at any good speed as the front end will want to lift. you can play with this link to adjust the angle of the hog when raised to find a happy medium.
Good luck
