Tea 20 85 carb need some info please
urban
08-05-2000 19:42:34
I have manual that identifies three adjustments on my carb.
1 is the idle speed stop screw 2 is the idle mixture screw
3 is the power jet needle screw.
I have figured out where # 1 is, but I cannot identify which of the other two screws is the idle mixture or the power jet. One is a round thumbscrew, the other is a slot screw with a spring on it. Can someone please help me identify which is which.
Pete Tatham
08-06-2000 23:37:14
 Re: tea 20 85 carb need some info please in reply to urban, 08-05-2000 19:42:34
If we are talking about the Zenith 24T2 carburetter, the slotted screw with the spring is the slow running mixture screw - turn clockwise to enrich the mixture. The screw with the circular knurled edge below the slow running screw is the main jet adjuster - gently screw right home then unscrew 2 turns for standard adjustment with engine thoroughly warmed up.
Hope this helps- if your'e still confused, e-mail me.
