HF inc. Southfield plant address.
Jeff-oh
11-14-2005 08:28:11
third party image
The interest in the street address of the Ferguson plant got me thinking. Here is what I found.
I asked John Polacsek of the Detroit historical society if they had any information on HF. Here is his reply.
The 1946 Directory of Michigan Manufacturers lists the Harry Ferguson company at 15020 Woodward Avenue, Detroit 3, Michigan It also noted that it was established in 1939.
(this is probally HF"s location during the 9N days-Jeff)
The 1953 Directory lists an address as P.O. Box 322 Roosevelt Park Annex, Detroit 32. If there was a local reference to the site we do not have anything on it nor a file on the company."
-end of Polacsek info---
I found this address from some government files. "12601 Southfield Rd. Detroit MICHIGAN 48232" This was for MF in 1979.
Searching this address on Mapquest.com it shows a large empty (industrial lot?) at the corners of I-96 and 39.
More information, I have states, "In Jan 1948 an option was taken on 72 acres of land on Southfield Road, Detroit, in the name of "Mr. Harlan"- a curious procedure prompted by the mysterious and sudden failure of another land transaction a few weeks before, which management felt was related to the dispute with Ford. ... The factory completion was set for July 31, 1948. ... Harry Ferguson drove the first tractor off the assembly line of the new plant on October 11, 1948. Before the end of the year Harry Ferguson Incorporated was assembling tractors at Detroit at a rate of 100 per day."
Attached is a photo of the plant. The train tracks in the picture are potentially the current CSX tracks that run on the north side of I-96.
Tim PloughNman Daley
11-15-2005 11:26:18
 Re: HF inc. Southfield plant address. in reply to Jeff-oh, 11-14-2005 08:28:11
Jeff-
The plant was changed to Massey-Ferguson when they merged in the fifties, but Massey moved operations to Canada in the early 80's and the Southfield plant was closed for good. Tis a shame that the good ones are gone for good from the area-Ford Tractor; Dearborn Farm Equipment; and Harry Ferguson; Inc. Ironic that their great machines will live another 60 + years!!! Tell that to your local Kubota dealer!
Tim Daley (MI)
*8N15513*
Jeff-oh
11-15-2005 13:58:18
 Re: HF inc. Southfield plant address. in reply to Tim PloughNman Daley, 11-15-2005 11:26:18
Yep, it is a shame. This all started because every one in a while someonw asked where was the plant. The knowledge that it was on Southfield road in Detroit is fairly common, however, I had never seen an address.
I did a little digging and there you have it. I love 1950's photos of places to compare to modern photos to see what has changed and what it newer.
Jim in OH
11-14-2005 19:39:06
 Satellite Image in reply to Jeff-oh, 11-14-2005 08:28:11
third party image
Here is the satellite image of 12601 Southfield Rd. Detroit MICHIGAN 48223.
It would appear that your picture was taken from the NE to the SW.
The link below is the same picture only larger..
Jim
BobinKY
11-17-2005 08:29:24
 Re: Satellite Image in reply to Jim in OH, 11-14-2005 19:39:06
Do you know where I can go to get a satellite photo of my farm? This photo is great and I would love to get one of the farm.
John (UK)
11-17-2005 10:32:39
 Re: Satellite Image in reply to BobinKY, 11-17-2005 08:29:24
go to Link and enter your zip. You will locate your farm on the map and then click on "satellite" and it will give you that view.You may be disappointed though , not all of the pics are as good, let's hope you are lucky.
Jeff-oh
11-15-2005 05:57:07
Thanks Jim,
As I see it, if this is the same site.
a) We know the original buildings are all torn down.
b) The rail tracks seem to line up.
c) It looks like the current warehouses are where the manufacturing plant was.
d) Looks like the two blocks where the Engineering Offices and the parking lots were are now residential.
c) If anyone goes there find out when the houses were built.
I may have to make a pilgrimage.
Jim in OH
11-14-2005 19:51:39
 Corrected Link to Larger Image in reply to Jim in OH, 11-14-2005 19:39:06
Sorry... JIm
Jim in OH
11-14-2005 13:53:24
If you search for that address (google), you will find a couple of trucking/moving firms. My guess is that it is at least partially converted/leased out for warehousing/shipping etc. Jim
Bill Brox
11-14-2005 13:42:42
Thanks a lot, that means I have been just 5 miles south of the place on the same road.
Well, it seems I need to go back. It will not be in 2006 as I had sort of planned, but hopefully in 2007.
Bill
Jeff-oh
11-14-2005 10:06:33
Note the Zip 48232 was transcribed correctly by me. It apparently was a typo in the gov. data. If you do a Map Search use the Zip 48223.
Also look closely to the North East of the indicated site there is a Ferguson St. I wonder if there is a connection? If you do not see it do a new map with the same Zip and Ferguson St.
Jeff
John (UK)
11-14-2005 09:33:30
Thanks for that Jeff, that fills in a lot of blanks that we had about the factory in Detroit. The boy done good!.....John
