TO-20
Irv Slagter
11-12-2005 18:31:36
Hi All,
I posted a week or so ago that I was looking at a to-30. I went and looked at it again and drove it. The engine was blowing smoke and rattled a little but had good oil pressure.
I kinda decided to look around a bit and found a TO-20 instead with an overdrive in it(yee haw. The tin's pretty straight and all the lights an badges are on it. Its been a golf course tractor and has turf tires on it now but the tires are sold on it so I have to get them. The motor was supposedly overhauled some time back, but here's the kicker. The distributer has been rebuilt in it but itis starting to throw metal inside the housing again. The feller I'm buying it from is pretty knowledegable, (owns a tractor salvage yard) and he said sometimes the cam gear gets loose on the cam and rattles the distibutor loose. Can any body put some light on this?
Thanks, Irv
By the way, I got it for $1300 and tax. What do you think?
Irv Slagter
11-12-2005 18:56:13
 Re: TO-20 in reply to Irv Slagter, 11-12-2005 18:31:36
I've been looking in the archives about cams being hard on distributors. Seems like a loose or missing nut on the cam gear is problematic and not that easy to fix. I'll check it out when I get it home in about a month.
Irv
Glenn/Calif
11-14-2005 19:34:12
 Re: TO-20 in reply to Irv Slagter, 11-12-2005 18:56:13
Hey Irv: Wish I had found that kind of deal. As John(UK) says, take the timing gear plate off and check it out. Get a Ferguson shop manual first, it's really helpful. The process isn't that big a deal. Don't know where you live, but it's really only a three or four hour job if you have a warm day or an inside shop. I did it in about 5 hours going slow and taking it easy. (I'm 70 something and don't go like I used to 30 years ago. But don't get discouraged, If the nut or some of the balls from the governer fall in the pan, a magnetic retreval tool will pick them out pretty easy. LOL. Glenn
Irv Slagter
11-15-2005 10:09:23
 Re: TO-20 in reply to Glenn/Calif, 11-14-2005 19:34:12
You're right, I need to get a manual for this old girl. Do you know if the one on this sight is a pretty good one. Some of those manuals kinda leave something to the imagination.
Did you have to take the front axle to get to the timing cover. I don't have mine home yet so, I'm kind of winging it. Sorry I'm so slow in responding, but it seems like I can't find the time to get on here.
Thanks, Irv
John (UK)
11-13-2005 07:48:44
Very wise to do that. Take the front off and look at the nut if it hasn't dropped off and in the oil pan.
