oil leak 1954 to-30 ferguson
cjim
11-11-2005 17:08:54
had the ferguson out about a hour and noticed oil on inside of rf rim looked and oil was leaking around govenor shaft and fan blowing the oil, is there a seal on the shaft? what needs to be done to repair?
John (UK)
11-12-2005 11:32:38
 Re: oil leak 1954 to-30 ferguson in reply to cjim, 11-11-2005 17:08:54
There are two oil seals on that shaft and both are different, there are two needle roller bearings also. To change them you need to remove the timing cover. If you want to do this I do have pictures and you will need info on how to reset the governor. Just email if you need them and tell me again what you are doing and give the tractor model.
