TE 20 Ignition Points
Robert Barrett
11-11-2005 12:16:22
I have a 48 ferguson TE20 im trying to find points for . Ive ordered TE20 points , they wouldnt fit. Dealer said by picture of cap, that the distributor had been changed to a TO20 Delco. I ordered points for that, wouldnt fit.My points have a insulated stand off on the points itself. With a thin copper strip between the distributor wire connection and the points. Can anyone tell me what i have.No numbers or markings what so-ever on the distributor.A part number for the points would be a blessing ! Thanks Bob
danct
11-12-2005 12:56:03
 Re: TE 20 Ignition Points in reply to Robert Barrett, 11-11-2005 12:16:22
Robert
i have a te 1949 and i looked today at the distributor which is still Lucas,on the bakelite cover where the plug wires go it says Made In England ,when i take the cover off there is a metal cover over the points which says TOP on the side that faces up,the rotor is also diffrent from the delco the points dont look much diffrent from the delco points on my other tractor if any of this looks familiar post back and at least you will know where to start
good luck
Danny
John (UK)
11-13-2005 07:21:10
 Re: TE 20 Ignition Points in reply to danct, 11-12-2005 12:56:03
If you need a reference number for those Lucas points it is Lucas 407050
Carlson
11-11-2005 18:52:50
The distributor make should be at the base of the distributor. The mfg. types are Delco or Lucas. Call Ashworth Tractor Parts and Equipment in Arkansa Tel. 479-442-9825 -- They know their stuff!
Duner Wi
11-11-2005 16:38:30
Seems to me I have seen Prestolite dist. in some old Fergys. These would be aftermarket replacement dist. Ask your nice parts man to show you pictures of Prestolite and Autolite points. You may be able to find what you need. Either that or find someone who sells the Prestolite dist. and compare with yours.
Jerry/MT
11-11-2005 12:30:40
I don't know what distributor you have but you'l have better luck finding the right points by looking for them by the make and model of distributor than by the tractor model number. Somebody may have put a distributor with a differnt model number from the OEM on your tractor.
