Weight Distribution TO-30 (or TO-20)
Jim in OH
11-02-2005 12:07:53
Anyone know what the typical front to rear weight distribution of a TO-30 (or TO-20) is? I think typical delivered weight was about 2900 lbs, but I would like to know the front to back ratio.
If you have numbers or percentages, please note the condition you are describing (whether you have loaded tires and whether it includes the driver, wheel weights etc.).
Thanks...
Jim
Jerry/MT
11-02-2005 13:37:18
 Re: Weight Distribution TO-30 (or TO-20) in reply to Jim in OH, 11-02-2005 12:07:53
Per the shop manual, the engine with the manifold and the flywheel weighs 375 lb.The operating weight (no ballast) is 2570 lbs per the owners manual and that includes tank full , lights. etc. I would presume that the operating weight would include all the fluids(lube oil, trans/hydraulic oil, steering gear box oil,coolant, etc.). If you have a scale nearby, you an weigh the fronnt end and the back end separately and figure out the weight distribution. If I was to take a guess, I'd say about 1/3 of the weight was on the front axle.
gshadel
11-02-2005 12:29:44
My daughter ran over my foot earlier this Summer, I would say the back is definitely heavier than the front, that was with loaded tires..... .. HA HA!
Sorry couldn't resist.
Beyond that, I don't know, that's a good question.
Most Fergys and N's I see loaded on trailers are loaded front facing forward. If the weight is that much different, might want to load the heavy end towards the front to help prevent fishtailing trailer.
George
