crank start a TO?
gshadel
10-31-2005 06:12:24
I noticed a while back that the handcrank notches on my crankshaft nut looked like they had some wear on them, which I thought was interesting. I saw a crank handle for a N at an auction, looked like it might work on a Fergy. I got to wondering... How hard would it be to hand start a TO-20???
Any of you guys ever actually crank started a TO-20/30 with a crank handle?
That's gotta be a back breaker, especially on a cold Winter day! I used to pull start 20 HP air cooled engines back in my Army days... some of those were really tough, and I definitely ain't as fit as I was back then. After a few tugs, we usually ended up hooking a long pull rope to the hitch on a Jeep, and take-off in the Jeep... That usually got the job done.
thanks
George
Crem
11-03-2005 20:57:05
 Re: crank start a TO? in reply to gshadel, 10-31-2005 06:12:24
We used to crank our TO-20 fairly often back in the fifties and sixties. We didn't always have a good battery and then it was either park it on a hill or crank it. we stored the crank behind the bracket on the fender that holds on the rear light.
lumpy
10-31-2005 17:56:36
I've crank started my 2n and 8n alot. nothing to it. The thumb with the fingers is VERY good advice. You want to crank start something, try a farmall super H. That will separate the men from the boys! I had to do it twice, only because I forgot to check the gas. Sh#t!
matt_in _ks
10-31-2005 15:41:03
I have been hand cranking mine for the last few months, since the starter started act up. I think it starts quicker than using the starter. Just my 2 cents.
gerard
10-31-2005 08:29:56
Piece of cake. Set throttle and or choke, make sure it's in neutral, switch on, engage handle and WITH THUMB ALONGSIDE FINGERS, give a smart pull up. Never push down. Easy peasy. Remember it may be a 2 liter plus engine, but you're only pulling one quarter of that at a time.
Jim in OH
10-31-2005 08:54:04
 Re: crank start a TO? in reply to gerard, 10-31-2005 08:29:56
A man of experience, no doubt... I think that you should have mentioned the consequences of not having the thumb in and not pulling up.... Possible broken bones!!!
I've started a model A many times (where I can retard the spark) and a TO-30 a few times (where I could/did not retard the spark) The latter was a little scary with the kick backs...
I think pulling it is the best advice....
Jim
gerard
10-31-2005 11:12:05
 Re: crank start a TO? in reply to Jim in OH, 10-31-2005 08:54:04
Never broken any bones myself but if you push & it slips or fires quickly, anticipate broken nose on hood. If you don't keep thumb on same side as fingers, broken thumb is possible, but hey, these are low compression, fairly docile engines. They start easy - biggest problem is being too timid. Go for it and it won't bite. Big single cyl diesels are a different matter - especially when they're anticlock rotation and the handle's on a parallel shaft.....
steveormary
10-31-2005 09:13:22
We would sometimes hand crank start our TE20.
No problem there.It takes some practice to work the choke right and where to set the throttle.
Be careful and be safe. Pull up on the crank,dont push down.
steveormary
