TO-20 Broken Starter Drive Housing
Mansel SoCal
10-30-2005 22:29:11
I haven"t had my TO-20 real long. But it has a problem that, by the looks of the bucket of spare parts that came with it, has been around for a while. Something keeps breaking the drive housing off of the starter. I don"t see any marks on the housing or flywheel/ring gear that point to anything hitting. I have tried a welded, but good used replacement from the bucket that lasted a few starts, then a new housing that went about a dozen starts before breaking. Does anyone have any experience with this problem or any ideas as to what would cause this?
Thanks everyone for the help & for all the great information I have learned the past few months here!
Mansel
gerard
10-31-2005 11:05:59
 Re: TO-20 Broken Starter Drive Housing in reply to Mansel SoCal, 10-30-2005 22:29:11
Unusual - have you ckecked timing and auto advance for proper functioning? Sounds as if engine is backing against starter.
steveormary
10-31-2005 09:06:02
Mansel,
Had that problem with my TO30.The first time the nose cone broke I had it welded. After several months use it broke again. Found a used nose cone and installed it.Learned that timming has tobe right on. I had my profesional assistent to help set timming.We set timming by the book and shimmed the starter out with shims cut from a pop can. Never had any trouble after that.
steveormary
steveormary
10-31-2005 09:06:00
Mansel,
steveormary
Mansel SoCal
10-31-2005 20:13:45
 Re: TO-20 Broken Starter Drive Housing in reply to steveormary, 10-31-2005 09:06:00
Gerard & Steve
Thanks for the sugesstions on timing. In answer to your question, no I haven't ever checked it with a light, always snapped it staic on #1 cylinder and then fine tuned the timing by ear. I'll clean out the hole in the block & shoot the timing with a light when I get the new nose piece installed. I don't know if it would warrant messing around with any shims. I used to have to do that to small block Chevys sometimes, but they all made a major "zing" noise that was hard to miss or ignore. Also left wear marks on the starer drive gear after just a couple of starts. I have no unusual noise and no marks on the gears. I forgot to add in original post that I had the starter gone through by a good local starter shop when I had the first welded housing put on. The bendix assembly still looks like brand new. Also charging system is 12 volt alt. conversion w/ 6 volt coil & starter.
Thanks for the help and I'll let you know how I come out after I get the new housing installed.
Mansel
