TO-20 backfiring through the carburator.
Dan Klingensmit
07-28-2000 19:08:35
When I need more power or give my TO-20 more throttle it backfires through the carburator. I'm not sure if the timing is off or if the carburator is out of wack. If anyone can help me out I would appreciate it.
Dan Klingensmith
07-29-2000 14:47:58
 Re: TO-20 backfiring through the carburator. in reply to Dan Klingensmith, 07-28-2000 19:08:35
Thanks for the help guys I really appreciated. The problem was that 2 spark plug wires were crossed and that caused to timing to be off. The old fergy runs like a charm thanks for the follow ups.
Pete Tatham
07-28-2000 23:33:21
Dan, Before you do anything drastic like pulling heads off, check your ignition timing, It sounds too far advanced to me. Regards, Pete.
Tex Ferguson
07-28-2000 19:37:07
Hey Dan, that sounds pretty alarming, having all that fire so close to the gas works. Here are a couple of ideas:
1. if your ignition is too advanced at higher rpm's, it might allow flame to travel through the gap of a closing intake valve. This might be caused by broken springs on the advance weights in the distributor. A timing light should show erratic spark at higher rpm.
2. Maybe one or more intake valves are chipped or have worn seats or "float" at higher rpm's. Any of these causes would mean they close tight enough to keep the fire inside the cylinder under light running conditions, but increased load, higher rpm's allow ignition past the intake valve back through the manifold. This one sounds like pulling the head for a professional valve job, including new valve guides.
Be sure to post your findings! Good luck! Tex
