Transmission Seals TO-30
J2 IN
10-25-2005 09:14:11
What seal goes where??? I ended up with a soft copper seal and a rubber O-ring both about the same diameter (about 2? inches)and have forgotten which goes where. (The seal kit came only with paper gaskets and no replacement for these.)
Which goes where?
J2
Jerry/MT
10-25-2005 10:33:47
 Re: Transmission Seals TO-30 in reply to J2 IN, 10-25-2005 09:14:11
My parts manual shows a seal (Part # 195 760 M1, It appears to seal between a land on the input shaft just ahead of the bearing and the shaft retainer assemble(the conical looking part that goes over the shaft). I've looked through my shop manual and it's no help. Maybe John UK has some info on this.
J2 IN
10-25-2005 12:09:36
 Re: Transmission Seals TO-30 in reply to Jerry/MT, 10-25-2005 10:33:47
Sorry if I was not clear.. These two seals either go to the fill port (on top of the transmission)or at the the big bottom drain hole... Neither of the parts that I have fit very well at either place and I am wondering what I don't understand. .. J2
John (UK)
10-28-2005 09:39:43
 Re: Transmission Seals TO-30 in reply to J2 IN, 10-25-2005 12:09:36
Sounds like the copper washer will fit the filler plug alongside the transmission lever, can't find the "O" ring mentioned.The plug underneath was also fitted with a copper washer. If I were doing it I think I would use the copper washer underneath and the "O" ring on the top filler plug as that would seal it ok and there is no pressure on it. If the filler plug washer is ok just don't replace the washer use the old one.
