TCO-20 valves
Delbert from Li
10-23-2005 13:34:43
You need one that looks like a big C clamp. Base goes on the flat of the valve, part that tightens down goes on the spring. Sometimes a 3rd hand or 3rd person is handy to keep the compressor tightened down, while getting the keepers out at the same time. Some compressors lock down. Around here you can rent one that will work for the job at some of the auto parts houses.
Delbert from Lincoln
10-23-2005 13:37:28
 Re: TCO-20 valves in reply to Delbert from Lincoln, 10-23-2005 13:34:43
This post intended for Phil a couple of spaces down, but they didn"t get hooked together some way.
gshadel
10-24-2005 14:05:53
 Re: TCO-20 valves in reply to Delbert from Lincoln, 10-23-2005 13:37:28
I saw this pic. in the "parts and pieces", I think this is what Delbert's talking about. This picture is on a flathead Ford, but turn it around and it should work just fine on a Continental.
I had a couple different spring compressors when I did mine, a generic GM spring compressor, and a generic Auto Zone job "for overhead valves", for different reasons neither one worked on the Continental. I ended-up using a small prybar, basically a big screwdriver with the working end bent to give you some leverage. That worked fine, I didn't have any springs or retainers "take-off" on me. I'm sure the right tool for the job would have been faster and less nerve-racking though.
George
