hydraulic lifting power w/new fluid.
guyeli
10-20-2005 12:22:25
I recently changed the hydraulic fluid in my TO 30 as the previous fluid was creamy w/water contamination.Prior to changing the fluid I noticed when lifting a 800 lb bush hog that squeeling noises erupted from the hydraulics.I immediately dropped the bush hog fearing I had exceeded my lifting capacity and damaging my system.Now with new fluid I'm wondering if my lift capacity will be enhanced so that I might be able to use this bush hog.Any suggestions?.
John (UK)
10-21-2005 13:08:48
 Re: hydraulic lifting power w/new fluid. in reply to guyeli, 10-20-2005 12:22:25
The squealing noise would be the safety valve blowing. Had the Hog reached max lift when it did this, if it had maybe there is something stopping it lifting all the way (check chains) if it hadn't reached max lift then most likely cause is the safety valve is worn and blowing off too soon. The tractor is capable of lifting a normal Hog. If the safety valve blows at any time you should not continue using the tractor with it blowing as it will wear the valve and reduce the pressure. You need to put a pressure gauge on the system and check the pressure which should be around 2000lbs.psi. and a minimum of 1800 to lift a Hog I would think.
Jerry/MT
10-20-2005 21:36:36
First of all new fluid won't help your lifting capability. Changing it gets a lot of crud out of the system and prevents any further probles caused by excessive water.(Water is incompressible just like oil.) At 800 lbs, you are at the lift capacity of the tractor (750-800 lbs)so the noise you hear maybe the relief valve opening.
gerard
10-20-2005 13:53:54
If it"s overloaded, either the front wheels will come off the ground or the relief valve will blow. Otherwise fine. Try it & see - can"t harm the hydraulics unless you run it constantly with valve blowing.
