can a TO-20 do this?
eferwerda
10-15-2005 13:08:14
third party image
I just made a 3'x3'x4' wood carrier (see picture) on a carry all. I loaded it up with seasoned oak and started carrying it home and the 3pt hitch gave out and dropped. I had a sliding bolt limiter on it (maybe i needed solid limiter bars?). I assume a seal of some kind gave out as it will barely lift anything now. What I need to know is : How do I fix this - any advice? and can a TO-20 carry this much weight - was the seal old and worn out, or was there just too much weight (holds about two-thirds of a face cord).
Jerry/MT
10-15-2005 19:22:56
 Re: can a TO-20 do this? in reply to eferwerda, 10-15-2005 13:08:14
Remeber that the lift capacity of this tractor is something like 750-800 lbs. You also want to be careful not to get the front wheels off the ground.
wayne2
10-15-2005 19:41:48
 Re: can a TO-20 do this? in reply to Jerry/MT, 10-15-2005 19:22:56
These sort of things sure worry a guy don't they!
marlowe
10-15-2005 17:10:30
just fix one of mine and it was the little gasket for the lift cyl. under the top cover bolts were a little lose so gasket went 2 hr. later all fixed
