TE20 engine
Lyle
07-22-2000 19:21:01
Does anyone know if the TE20 engine has wet or dry sleeves and what is the correct method to remove and replace them.I believe this tractor has a Standard Motor instead of a Continental.
Robert Ferguson
04-06-2001 08:23:08
 Re: TE20 engine in reply to Lyle, 07-22-2000 19:21:01
Water in oil is my problem. I work the tractor 5 or six hours and change oil. Puting things in raditor does not fix the problem.
Have other lovers of the fergie experienced this problem? I am looking for a $1000.00 or less fix. $2000.00 would purchase another te20 so if repair is too costly it is just not worth it.
DHunter
07-22-2000 20:13:54
I have a TE20 and it has a Continental Z-120 engine. I think the TEA20 had the Standard engine. You should consult the manuals for the correct method of removing and replacing the sleeves. They are readilly available on this site.
stephen cotton
07-25-2000 17:13:32
 Re: Re: TE20 engine in reply to DHunter, 07-22-2000 20:13:54
There are 2 standard sizes, 80mm and 85mm, these are wet sleeves, and must be pulled up from the bottom, ie you have to take your sump off. Be careful fitting new figure of 8 gaskets as different suppliers will supply various thicknesses. The incorrect thickness, could mean that you could crack the block when torqueing the head. Use a little smear of gold instant gasket on these gaskets when fitting and don't fit steel gaskets. The important thing is when fitted, make sure that you clamp them down using washers, tubing and the head studs, if you intend to turn over the crankshaft to fit your con rods.
Any more queries, e mail me
Yours Stephen
