starter problems
Gene in La.
10-06-2005 20:11:07
My starter went south and I need to have it rebuilt! My question is can it be rebuilt for a 12v battery (that is what I use (12v) to crank it and then disconnect) or should I keep it all a 6v system. The generrater shows putting out 14v. Also am I really hurting anything doing it this was! I've noticed on hight rpm it tends to cut out; only when battery is disconnected, running it this way (why?) but runs fine when I reconnect 12v battery.
Thanks; yall have answered all questions I've every had and then some, thanks Gene in Louisiana USA
BobinKY
10-11-2005 04:31:42
 Re: starter problems in reply to Gene in La., 10-06-2005 20:11:07
For what it is worth, I converted my old Allis Chalmer WD about two years ago to twelve volts. I still use the six volt starter with a new Delco Alternator and internal regulator. I converted the points system to Petronix (Appx $150 for ignition and coil) and I have not had any problem with this system since that time. The tractor starts on the first or second spin, even when it sets for two or three weeks. I never imagined that the old girl could have as much power as the Petronix kit opened up for me. I highly recommend this particularly for weekend farmers as the points are a pain in the tail. They make this Petronix kit for six or twelve volt systems. Hope this helps and good luck.
Gene in La.
10-07-2005 21:39:01
Well ya'll, plus the owner at the started shop, have convinced me to keep it at 6volts and just buy a 6 volt battery, and keep the 12 volt battery as a backup back on the shelve and charged up for future use.
Thanks fellow's for all the great advice!!!
Gene in Louisiana.
Crem
10-09-2005 19:17:27
 Re: starter problems in reply to Gene in La., 10-07-2005 21:39:01
I am a 6 volt system man, but just today I talked to a guy who has a few TO-30's and he told me how he converts the starter to 12 volts. His father was a Ferguson dealer and he grew up around the Fergusons. He gets a 35 Ferguson starter snout and it will attach to a older GM 12 volt starter with the solenoid attached to the top of the starter. He said that it works well and he doesn't have trouble with breaking the front housing as he did when he put 12 volts on the old original starter. I took a picture of it and can get more info from him if anyone is interested. He also has a TO-30 with a loader turned around and mounted on the rear of the tractor. The seat sits on top of the hood and faces to the rear. He swapped the rear end ring gear to the opposite side so that he would have four speeds backwards. The clutch and brakes are also swapped to the opposite side along with a different steering system. He built this himself and it must have been quite a project.
Jerry/MT
10-07-2005 13:23:58
Actually using a 6 volt starter at 12 volts halves the current during starting and is easy on the starter from the standpoint of resistive heat in the windings. I have had the original 6 V starter on my TO-30 for over 10 years running with a 12 V conversion with no starter or ring problems what so ever. Mine is a working tractor, too.
Jim in OH
10-07-2005 14:52:13
 Re: starter problems ??? in reply to Jerry/MT, 10-07-2005 13:23:58
???? "using a 6 volt starter at 12 volts halves the current during starting" ????
My math says that double the voltage, you will double the current (and four times the resistive heating).... I agree with the post that says keep it to short bursts...
If you want to take into account the characteristics of DC motors under load, then I would agree that it is not quite as bad as double the current, but you would have a hard time convincing me that if you double the voltage (across a 6 volt starter)that the current goes down.... I think that maybe you have assumed that the 6v starter has been converted to 12 volts. In that case, I would agree that the current would be about 1/2... Jim
Jerry/MT
10-08-2005 11:04:18
 Re: starter problems ??? in reply to Jim in OH, 10-07-2005 14:52:13
Your are right, Jim, and I am sorry for making that erroneous statement. I went back and did my homework and found that the starter motor is a series motor (field in series with the armature)not a shunt motor. Therefore the current is proportional to the voltage if the resistance is fixed, which it pretty much is. I apologiz e for making this error. But I learned somwething in the process. Thanks for calling me on it.
Delbert from Lincoln
10-07-2005 11:20:15
If I were you, owning a 12 volt battery and generator, I"d get the starter rebuilt. Some shops are capable of converting it to 12 volts. Others are not. It will work just fine, 6 volt starter on 12 volts. Only thing, don"t crank it over 30 to 40 seconds at a time. Then I presume this system is negative ground, most 12 volts are, reverse the primary wires on the coil so the pos goes to the ignition switch, and negative goes to the points. Add a resistor, available at auto parts house, tell them what you want it for, the one I use on my TE-20 was supposed to be for Chrysler. Then you should be set to go. Tractor will start better, if you ever want to use a small sprayer with electric pump, voltage is right, and it is compatable with other vehicles if you need to jump start it, or need to use it to jump start something else. Thats what I did to mine, only I am using a GM alternator with builtin regulator.
John T
10-07-2005 05:55:32
Gene, a good starter repair shop can convert the starter to 12 volts, but I would fix the system and keep her at 6 if it were mine. You can even use a 6 volt starter at 12 volts, they spin realllll l fasttttt tt but it can be tough on starter drives and/or flywheel teeth. If the engine and ignition are in top shape and you use the highest rated 6 volt battery that will physically fit into the compartment AND USE 00 GAUGE BATTERY N STARTER N GROUND CABLES, she ought to start okay if the starters good.
That 12 volt generator could be used on a 6 volt system if you install a 6 volt Voltage Regulator on it.
If youre running a 6 volt coil at 12 volts, it will run hot plus the points will burn up prematurely. On those tractors they either add a series voltage dropping (12 to 6) external Ballast Resistor ahead of the coil or else use a full 12 volt rated coil.
Theres more but im headed to an auction, post back any questions and I will check with ya later.
John T Nordhoff in Indiana, retired electrical engineer
