grey and gold ferguson starting/running problem
ED HOCKNELL
10-01-2005 03:46:48
I have just rebuilt a 23c diesel engine-total recon head,new pistons&liners.the timing is set at valve rock on number 4 at TDC,the fuel pump is lining up letter G with mark with timimg peg in the flywheel on 16degrees BTDC no1 compresion stoke.appears to have plenty of compression. After all that it will only start with plenty of the EVIL etherstart.When i can finally get it going it fires evenly but can barely keep going even at full throttle.any attempt to reduce revs results in it slowly dying until it stops completly.I have checked timing more times than i can count and am just about at the point of total despair.can anybody suggest a possible cause/remedy.I know 23C's are reluctant,my dad recounts stories of a neighbour who had a FE35 from new and had to tow it up and down the lane for hours,eventually it was abandoned in a layby.one of many FE35 doom stories I hear. Thanks. ED
gerard
10-01-2005 12:46:37
 Re: grey and gold ferguson starting/running proble in reply to ED HOCKNELL, 10-01-2005 03:46:48
I remember, must be about 1967, doing a total rebuild on one of these - including new pre-combustion chambers - and still had to tow it to start every morning! Some were better than others. They didn't have a Ky Gas system for nothing. Using ether won't wreck your engine as some claim, PROVIDED you use it sparingly. If engine starts to knock, you're using too much.
As to your problem - if the timing genuinely is OK, sounds as if you might have a governor problem in the inj pump.
