T030 Governor Adjustment
Greg in Indy
09-27-2005 08:42:17
Just had engine rebuilt and now having trouble with throttle. Under a mower load the governor cycles back and forth instead of a constant increase in the throttle. Also when i push the throttle lever all the way up the idle is so low the engine dies. Does this sound like a governer adjustment problem? None of the carb linkage was changed during rebuild. If i increase idle will that affect governer cycling back and forth. How hard to adjust governer? Thanks again guys for all your great advise.
John (UK)
09-27-2005 12:18:31
 Re: T030 Governor Adjustment in reply to Greg in Indy, 09-27-2005 08:42:17
If you have had an engine rebuild you have changed the governor linkage settings. It does sound like governor adjustment. If you want the information on how to set the governor, email:- fergusontractors (at) tiscali(dot) co (dot) uk and tell me again what you need or just send a copy of your email here and I will mail it straight back to you....John
Greg in Indy
09-27-2005 12:45:31
 Re: T030 Governor Adjustment in reply to John (UK), 09-27-2005 12:18:31
Thanks John My email is [email protected] Thanks again
