TEA20 transmission stuck in Reverse
Jon Darrow
09-26-2005 17:24:49
I own a 1952 TEA 20. The transmission seems to be stuck in reverse. It was working fine. I shifted to reverse and now the tranmission will not shift to any other gear. The clucth works fine. This is how I moved it, pushing in the clutch and towed it. thanks for any help
John (UK)
09-27-2005 06:01:20
 Re: TEA20 transmission stuck in Reverse in reply to Jon Darrow, 09-26-2005 17:24:49
Does the lever move around without seeming to connect to anything, if it does the gear lever has come out of the selector, just remove the lever and drop it back into the selector again. While you have the lever out see if all the selectors are lined up (neutral) if not line them up and it should be ok. If they are lined up and it is still stuck in reverse you may have broken a selector and this will require the box stripping down. If you require more information about this, email:- fergusontractors at tiscali dot co dot uk
and tell me what you need and what the problem is and I will send you the information you need to put it right.John
Jon Darrow
09-28-2005 14:42:30
 Re: TEA20 transmission stuck in Reverse in reply to John (UK), 09-27-2005 06:01:20
I removed the selector and placed it back in the correct position like was suggested and everything worked again. Thanks for the help
wayne2
09-29-2005 06:07:03
 Re: TEA20 transmission stuck in Reverse in reply to Jon Darrow, 09-28-2005 14:42:30
Isn't John(UK) Great!!!
John (UK)
09-29-2005 12:38:11
 Re: TEA20 transmission stuck in Reverse in reply to wayne2, 09-29-2005 06:07:03
HA HA not everyone thinks like you Wayne, there are a few on here who hate my guts....lol but thank you anyway.....John
